8.4 screen blank then begins to flicker
rob.stack1
I just went out and started my truck. I noticed that the radio screen was black and no music was playing. I shut off the truck and let it sit for a few minutes. I started it again with the same issue. This time I let the truck run a few minutes since it’s cold in New York. The screen eventually came on and would turn on and off on its own. No music would play and I couldn’t adjust the controls. Anyone have any input on this? Here’s a video of what it’s doing.
https://www.youtube.com/watch?v=RE6x6GgypGs
RamCares
n/a
n/a
Hi rob.stack1,
We're sorry to hear about this - is this concern still happening? Please PM us with your VIN if you need further assistance.
Jennifer
Ram Social Care Specialist
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
My thoughts after watching your video of this issue:
- This doesn't look like the cold weather/bad solder joints in the radio issue.
- Did this start after a recent radio SW update to 17.x ?
- This kind of looks like a bad signal from the HVAC bezel, ie the "BACK" button is sticking or the chip on the board is failing.
>>> Try disconnecting the small 8 pin connector that only goes to the HVAC/volume bezel and see if it continues to blink on/off. If it stops then it's definitely the bezel.
Let us know how it goes.
PS: do you have a single zone or dual zone HVAC bezel
M² Mods - From my non Flammable S7!
R
rob.stack1
Thanks for the response. I tried that and will have to see if it will continue to do it. It doesn’t happen every time I start the truck which is stumping me. I have dual zone
R.L.K.
Bristol , Tn.
Hmm that is strange in deed ...
Is your video after the soft reboot I sent you via PM ?
R.L.K.
Bristol , Tn.
I'd definitely try what Mpgrimm2 suggest !
R
rob.stack1
That was before but the same thing but happened after I did the soft reboot. I did what grim said and just waiting to see if the issue happens again.
R.L.K.
Bristol , Tn.
Got it ! ...Trust me when I say :
Mpgrimm2 / M2mods is/are a fantastic source for troubleshooting these RA radios & most other electronic type issues with the 2013++ Rams ....your in Good Hands with M2MODS ...imho!
R
rob.stack1
He’s definitely very knowledgeable, it’ll be tough to do his suggestion because this issue lasts about 45 seconds and goes back to working
Ricks Ram
If your problem continues after you try what was suggested you may want to try installing your original 8.4 radio if you still have it. If the problem persists you can rule out the other issues and focus on the radio itself. Of corse that's only if you didn't sell your original 8.4 VP4CA. Just thought I would mention it just in case you still had it.
Sent from my SCH-I545 using Tapatalk
R
rob.stack1
I actually returned the one I purchased from infotainment. That radio wouldn’t shut off on its own so I returned it.
R.L.K.
Bristol , Tn.
So what's infotainment have to say about your current issues ?
Petawawa Ontario
This happened in my fiancé's Journey last year. We had to take it to the dealership to fix it. They ended up having to change out the whole stereo. May wanna look into that
R
rob.stack1
THATs what I was afraid of, but my truck is out of warranty
R
rob.stack1
Looks like there might have been a loose connection or something. The last time I took the dash apart I disconnected everything and then put it back together. So far no issues
R.L.K.
Bristol , Tn.
That's fantastic information , hopefully it stays this way !!
So do you think it was the HVAC connection ?
R
rob.stack1
It could have been, I disconnected that connection as well.
