Tonyg1103
it cranks over, acts like it wants to start but won't. I can hear fuel pump in tank, fuel pressure is good at rail, coil is sparking, I've pulled each plug and turned it over and they're are all sparking....plugs were all pretty wet with fuel when I pulled each. I've even sprayed ether in TB and still nada. Would a faulty cam sensor (pick up coil) or crankshaft sensor cause these symptoms? Or would yhere be no spark or no fuel with faulty sensors? Coolant sensors? Thanks in advance....tony...hoping for suggestions to try rather than just throwingparts at it.
