A/C Fan Dies Down
MikeG71
U.S. ARMY '02 - '12
Cheyenne, WY
06 Mega 2500
While A/C is running putting up a window the fan dies down some when the window stops up or down. Also when stepping on the accelerator the fan speeds up.
Is this a sign of the Alternator starting to crap out?
justin13703
MD
Nope, it’s normal especially on the 06-08 trucks. Nothing to worry about.
MikeG71
MikeG71
U.S. ARMY '02 - '12
Cheyenne, WY
06 Mega 2500
Thank you Sir!
Would upgrading to a bigger Alternator solve the issue? Would it even be worth it?
justin13703
MD
Thank you Sir!
No problem, as far as upgrading the alternator, I personally have no experience with this but I don’t believe this would solve the issue because on the 06-08 trucks the voltage regulator is in the computer. So there always is a slight delay between a power demand such as running power windows, and when the truck actually sees this and responds by upping the voltage. That’s why at least with my truck, you’ll see the lights kind of dim, then brighten up about a half second later. It just takes the truck a short time to see what’s going on and adjust for it.
Using an external voltage regulator would probably get rid of the issue but I think it comes with its own set of obstacles.
MikeG71
MikeG71
U.S. ARMY '02 - '12
Cheyenne, WY
06 Mega 2500
Sounds good to me. If that's what the Ram does then that's what it does.... lol!
Joey93
