- Jan 17, 2016
- 14,050
- 24,365
- 14 Sport
- 5.7
Cheesman has a fairly good video up on fixing the ABS module. I figured i'd post it up by itself as there's about 2 dozen ABS threads going,lol
About all i'd add is to take a small fine tooth file and also clean up the inside of the brush housing,after sanding the brushes slightly.We used to sand the brushes with 600 grit or higher wet/dry sand paper,but 320 like he used will also work
RAM ABS Code C0020-01 FIX!!! on 2017 5500
Here is a video i made to help all you Ram owners with the dreaded abs code c0022-01. This was on a 2017 ram 5500 cummings. The complaint will be abs light a...
www.youtube.com
