ABS Light Traction Control and service 4wd light on
hellraiser7918
Hi guys im new to this forum but I just purchased a 2012 ram 1500 with the 4.7. When ever it rains out and when going threw car washes the ABS light traction control light and the Service 4wd light come on. After a few minutes of driving in the dry pavement they will go off the following time I restart the truck. And of coarse I took it to the dealer and they could not duplicate the problem. any help would be greatly appreciated. Also the cruise doesn't work when this happens
twenty12ram1500
Long Island, NY
had similar issue, sounds like one of your abs/esp lines to your hubs is exposed and every time it gets wet it shorts out causing thos lights to come on, check your esp/abs lines in the front that go from your hubs to a connector under the front wheel wells
sabo
