Huh?? There better not be air in your system or you have bigger issues. May I reword that? ....... The orfice tube restricts how much refrigerant can flow into the evaporator. Through the use of small orfices(hence the name), the liquid refrigerant from the high pressure side is misted into your evap coil, allowing the more efficient exchange of heat with the surface of the evap coil tubes. it is then sucked out of the evaporator by the compressor, where the mist is then compressed (hence the name). The compression of this mist creates friction among the molecules, which creates heat....The compressed mixture, is pumped through the condenser to remove that heat and "condense" it (hence the name). Make sense OP?
