AC works under 1.5k rpm
DarthHemi
2004 1500 SLT quad cab long bed 5.7
When parked and idle the AC clutch will sometimes kick on and then just stop
While in gear, if I slow down in traffic and rpm drops below ~1.5 the AC will work, the clutch kicks on
While in gear and above ~1.5k rpm the clutch will disengage and not run
Vehicle has ~350k miles and the AC Compressor looks original. Im considering just replacing it the compressor with one from Rock Auto. Which one does everyone recommend?
If it may be something else, Im happy to diagnose.
Thanks!
D
DarthHemi
Clutch coil is returning 4.2 ohms which is good
pacofortacos
You have to check to see if it is electrical or mechanical.
Test for voltage at the coil and see if you have 12 volts and ground there when the clutch is not engaged.
If you have voltage and no clutch engagement then it is the compressor clutch.
If you don't have voltage then it is elsewhere.
PoMansRam
East Aurora NY
As a blind guess the pressure switch may be commanding the compressor to cut off as pressure builds at higher RPM. Could be low on refrigerant, could be a faulty press switch, the condenser could be plugged, etc...etc..
pacofortacos
You don't mention checking pressures. Could simply be a leak and low on charge. I'd certainly be checking that before replacing a compressor.
If you don't have a set of gauges, you might be able to get away with checking the low side pretty cheaply using the stuff the guy in this video does.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I was going to do all of that myself and try to save some money, but in the end I said just let a trustworthy shop do it. Comes with a warranty and I don't have to mess with it. I'll do anything if I have the right tools, but those AC tools are tools I don't have.
D
DarthHemi
So I checked the relays. I switched fuel pump and AC clutch, no change. I replaced the AC Fan control and it worked for like 20 minutes and stopped working.
I checked Low pressure line and was at 100 psi. Rechecked power and no voltage to compressor.
What can cause no voltage to compressor?
Thanks
D
DarthHemi
If i jump 12v everything seems to work fine. Does that mean a AC pressure sensor?
jws123
nj
Thanks
If it was 100 PSI when compressor is running then it has to much. It needs to be checked with ac compressor running bet your low on refrigerant.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
What's the low side pressure with the compressor running? Maybe watch that gauge for 20 minutes and see what happens to the pressure when it kicks off.
pacofortacos
If your low side is @ 100 psi WITH the compressor running, it might be a bad orfice tube, plugged receiver drier, or really over charged. The pressure switch is most likely turning off the AC because of a pressure problem.
They used to have expansion valves years ago, but I think yours uses an orfice tube. I don't know if the tube is before or after the drier.
Administrator
an orfice tube (or any expansion device) will be after the receiver/drier in a refrigeration system.
D
DarthHemi
If I give 12v straight to the compressor why does it work?
I read high side under load is over 200 psi. When both sides are 100 (I didn’t check high) it means the compressor isn’t running and not getting voltage.
D
DarthHemi
So its working, for now, in my driveway.
TLDR - Replaced AC Fan relay, then AC temperature switch, then AC clutch 10a fuse.
TLDR 2 - check your fuses first to make sure
Full story:
It was running yesterday after replacing the AC Fan relay. Then driving down the road it just stopped. I troubleshot the issue. and noticed no power coming to compressor. As part of this troubleshooting I was connecting leads to the wiring harness and compressor. Im speculating here I did something to blow a fuse.
Replaced the AC temperature switch this morning. Nothing worked. Checked AC Clutch fuse and it was blown. It would have been nice if I would have checked the fuse prior to replacing the switch (I guess I could put the old one back). Replaced fuse. It is running properly in my driveway.
Checked low side AC, was at ~30psi. Brought it up to ~40 with some additional r134a. All seems well.
Since Im a betting man, my speculation is that after another 10-15 min of driving im going to blow another fuse. If that happens signs are pointing to a rusted/semi-seized clutch which would indicate a compressor replacement, no?
Thanks again all for the help
pacofortacos
I know the expansion valves were, but I couldn't see where it went in a diagram and wanted to not give information that I was unsure of.
I thought they were usually always right at the evaporator inlet.
pacofortacos
Full story:
Most likely, you could unplug the clutch and drive it a few days (with the AC on - though not working) and see if it blows the fuse and if it does, that would indicate a short elsewhere. If it doesn't then it is most likely the coil and since they really don't sell the clutch/coil as much as they used to ( I used to replace those often years ago) you would need a compressor.
