Add LSD after market?
ctc
HEMI 5.7 etorque
Can this be added to a 2024 after market?
ctc
ctc
HEMI 5.7 etorque
Dealer is telling me no....
danielmid
Southeast WI
2015 Sport 4x4
Thats the last place you should go for a LSD.
Find an offroad shop that specialises in gear swaps. They'll throw in a TruTrac ;)
I don't know if a TruTrac is out for the 2024s? The one Eaton lists for the Ram 1500 (which is what I'm running) only shows up to 2020.
Might have better luck finding a dealer who will swap out for the factory lsd rear.
ctc
ctc
HEMI 5.7 etorque
They told me the computer has to be reprogrammed for everything and that they can't even add a charging pad, let alone a LSD.
2003F350
6.7 CTD
My dealer would probably do it, even if the truck was under warranty, and not void the warranty - as long as I keep bringing it back to them.
If your dealer claims they can't add the charging pad, they're full of **** - I had the ETBC added to my wife's truck (a bit more than I was expecting but still fairly cheap) and no issues with the warranty. It sounds to me like you've got a dealer that just wants to do oil changes, and I'd be looking for a different dealer if you want to keep going to a dealer (which isn't a bad idea when you're under warranty, if you're worried about such things - some people aren't, I personally am).
Am I paying more for peace of mind? Probably. Does it bother me? Not really, since I have a pretty competent service department and a good working relationship with the service manager.
Cmz2800
NC
Do you feel any difference running lsd? I mean, unless you have a ton of power or want to do some good doughnuts, I wouldn’t think it would really matter. Or am I just plain out wrong?
Units
Ms
2023 Bighorn
6.7l Cummins
If the OPs truck is 2wd then it would most definitely be beneficial, no one wheel peel.
I had a 2wd truck that I had a limited slip installed in that didn’t have it from factory and was able to go way more places than I ever could with an open diff, just couldn’t be scared of the skinny pedal. It all depends on the OPs intended use.
ctc
ctc
HEMI 5.7 etorque
I have had LSD on all my RAMs except for my 2019. I definitely noticed a difference when starting on gravel or grass that was on an incline. It was the only thing I didn't like about my '19.
ctc
ctc
HEMI 5.7 etorque
Yeah I'm headed to another dealer today. They have 2 trucks with LSD on the lot that are in my price range so I hope to be driving one home this afternoon.
danielmid
Southeast WI
2015 Sport 4x4
I have found no situations where it was a negative to have the TruTrac versus quite a few where it's been beneficial to have it. Ice/snow no longer just spins one side (hill leaving my neighborhood and stop light on a hill going to work), backing the camper on grass and forest camping roads, leaving a stop light, I don't have to worry anymore. It was worth it IMO, but I was coming from an open diff, if I had the factory LSD it likely would have been absolutely fine for my needs.
ctc
ctc
HEMI 5.7 etorque
Thanks everyone. I pulled the trigger on a 24 HD Rebel. Definitely made sure it had factory LSD.
Tominator223
2 wheels actually driving it. Is always better than 1. Without an lsd in the back. It’s really only 1 wheel drive . Which you’ll find out in mud ,gravel or trying to get your boat up the ramp. Not to mention the $nuts. Lol
