Adding DEF without leaks?
Fuel35 67
Hanford
If the OP deleted, he/she wouldn’t have the ****’n problem. Now do you understand? I left, you should’ve left it alone. Start being able to put 2 and 2 together. Leave me out of this thread. I’ve said my peace.
John Jensen
San Diego County
Ecodiesel
I clearly understood your simple original post. It was your subsequent post that I asked, "Who do you think didn't comprehend your simple post? Or, why did you say that?"
They remain unanswered.
I've said my peace as well. Cheers
BigLazer4u
North Carolina
Cummins
Calm down before you have an aneurism, he answered your question multiple times and you continue to argue
John Jensen
San Diego County
Ecodiesel
No, he didn't. If I missed it, please show me his answer.
I am calm. Thanks for your concern :)
I'm also done with it, not worth it.
Tony1945
Needles
Ram 2019
V8
After moving from diesel to gas and back I now find that my diesel requires DEF (my last diesel, a 2006, did not). I have not found a way to add DEF using the nozzles provided with the product without having fluid leak out through the little rubber vent at the nozzle. I can't believe everyone puts up with this so I must be doing something wrong. For now I am transferring to another container and then adding to the truck. Any tips, suggestions?
Same problem could not get breather up without leaking at threads ‍♂️1655743493350.png1655743493350.png
Tony1945
Needles
Ram 2019
V8
Same here , leaked breather or threads
Tracy in IL
Moline IL
3.0 diesel
I always get leaks too. Started pouring directly from the 2.5gal bottle into a narrow neck long bowl channel. No problems since. Keep the funnel in the Ram box.
Floyd1979
Punch a small hole in the back end at the top for added vent .
jvbuttex
I-6
every 3 to 4 tanks...no issues dribbling here.
jvbuttex
I-6
Let's get back on topics folks, keep in mind I'll win any argument you're thinking of starting or continuing.
ha ha ha.... yes, yes you will .
randyr6
MD
cummins
Yep, as always. When one can't answer for what they say, they leave with criticism.
Your so right-He lost me from the beginning. I love reading these post for the info I get but comments like Fuel's leave me lost for my common sense-no matter how hard I try I can't make sense of the post. Its as bad as when people leave comments like "ditto", "I agree" "I have nothing to add" to a post. Its not hard to let people know what you're thinking but it may take more than a few words, that will make sense to the rest of the world! I haven't had to add DEF yet but my 2022 came with a special funnel under the passenger seat-doesn't it help?
jvbuttex
I-6
Hello there, not everyone knows everything like you obviously do. How about let people ask the questions that is important to them. Just like my young son / daughter, asked silly questions some times, yet we as adults entertain it ang give them answers.
tcass
Southern Maryland
3.0 V6 Echo-diesel
so, new to diesel with def also. brand new rebel Echo-diesel and havent had to fill up the def tank yet. when you get the def at gas stations, where is that normally located or what stations carry the def. i have a jug to put in but was wondering about filling at the station. used to have a Cummings in my 2000 2500 long ago.....didnt need no stinking DEF......lol
Administrator
If you have any truck stops near you, the DEF pumps will be right next to or the same pump as the diesel pump. There a what I would call a mini truck stop that has three diesel fuel bays couple miles down the road from me. You can use Google to find a station.
You can pump the DEF directly into the truck DEF filler but go slow, just like the semi truck diesel pumps they're a lot faster than regular pumps.
BossHogg
Oakland Township, Michigan
6.7L Cummins
I prefer using the 2 1/2 gallon jug to refill the DEF tank. I've used the DEF pumps a few times but I always get that bit of dribble from the DEF nozzle no matter how careful I am which results in a small collection of DEF in the fill area which becomes white and it is almost impossible to clean out of the small areas.
Maybe I'll try using a towel to catch the end of the DEF nozzle next time.
jejb
NW Arkansas
Another option would be to refill your empty 2.5 gallon jugs at the DEF pump.
Scrounger
Charlotte nc
2019 2500 mega cab 4x4
6.7 I6 Cummins
Black vent needs to be topside, never had a issue
