Additional UAQ/UAS Update Files 28.3/30.24/34.2
18harvest
huntsville
Well I be damned adding the map pack from 21.9 to the 30. Worked my nav now works.if I can make it a day or two with no black screen I will be good to go.clearly stabIle. What application or you running on the ah radio and how long have you ran it? If yours is running good mine should it's the same part number
C
ClearlyStabile
Colorado
Hemi 5.7l
Awesome! Woo hoo! That's what I did on my wife's jeep to fix her navigation. I just put the 22.5 map pack on the 34.2 install file and it fixed her nav. Then we had the issue with the SiriusXM favorites swapping around so we switched it to 30.42 to get that working again, but I think it's still doing it. Not doing that at all on my RAM, so I think I'm going to update the RAM back to 34.2 (the AH).
18harvest
huntsville
Sorry just saw the post on the maps.I do not know to be honest on the uaq radios.the ra4 radios you can get a USB from chrysler or I just go on ebay and for 100.00 they send you a file you load it and then it will ask you for a code you send them a screen shot of the request code then they send you a activation code.they are in the UK so you will have to do some time zone math.but I usually just what until the next day and put the code In. It's like 2:00 am my time when it's afternoon there
18harvest
huntsville
no major problems today with the 21.9 map pack and 30.24 application.1 no matter what i leave the sourse on it goes back to cd when i turn the radio on.not a problem if you just remove the cd.2 use nav and avtivating nav pops up for like 5- 20 seconds and then its good.trying the 32 or 34 which ever it is with the 22.5 maps now.
Cesar592
3.6 pentastar
how did you add map package to 34.2 files
C
ClearlyStabile
Colorado
Hemi 5.7l
The way I did it was just download 22.5 and copy and paste the map_package folder on the root level of the flash drive along with the update file.
Cesar592
3.6 pentastar
you can take some photos to see how the files are in the usb
PdPuNOme
Jersey
I am looking for the 22.6 files as another thread and source only had the firmware but no map pack included. Anyone have the complete ram specific v22.6 full update with map packs they can share?
C
ClearlyStabile
Colorado
Hemi 5.7l
22.6 doesn’t have the map pack. You’d have to download 22.5 and install it and then 22.6 or add the map folder into the 22.6 update file.
PdPuNOme
Jersey
I am currently on software version 18.20.2e and Application version USA-IR-21.9.0-20180516-109v, so not sure if I am 18.2 or 21.9, label/sticker on uaq was 19 something which i know those indicate software version or at least from what I have gathered from others.
Where can I get my hands on the 22.5 map/software pack?
PdPuNOme
Jersey
Thanks, I have the 22.6 file, but I am after the mentioned 22.5 which is to include the map files as well.
sawz
Aldie, VA
2015 Ram 1500 QC
Do you have any other UAS versions?
sawz
Aldie, VA
2015 Ram 1500 QC
I took the plunge and updated my UAS to 30.24. So far I don't see any issues, everything seems to be working. I had the loud announcement/warning volume issue on 22.6 that some others have reported, don't know yet but hopefully this fixes it. I'll know in about 20 minutes when I go for a drive.
sawz
Aldie, VA
2015 Ram 1500 QC
24 hours and everything seems to be working properly. Warning alert volume is working properly and even maintains setting changes between starts.
aibrahimov
US
V6
@ClearlyStabile, first of all, thank you for posting these updates!
Here is something interesting I found - it looks like the 30.42 update is supposed to contain the maps from 2019: there is a map_package folder and navi_map_metadata text file in it says:
"PROD_2019.03.28_MY20_CW13_LUNA_CONTENT_NA"
vs.
"PROD_2018.05.08_MY18_CW19_LUNA_CONTENT_NA" in 22.6.
However, navi_map subfolder, which usually contains the actual map files, is missing. Any chance you can check with the source of these files on that?
Thanks again!
