Advise on towing
mountainlion
Anacortes
6.7l I6
Hi guys,
Have a 3500 SO 68 RFE.
When I talked to the salesman he recommended to only use gear 1-5 when towing
on the freeway. (Eliminating gear 6)
Going up steep grades he said use gear 4 if it is hunting between 4 and 5.
My travel trailer is about 9000 lbs fully loaded. So not so heavy.
I fully understand the reason to go to 4 on steep grades as it prevents unnecessary shifting.
Would appreciate if you would share how you are using the gearbox while towing.
06 Dodge
Forest Grove, Oregon
6.7L CTD
One other thing when towing I like to keep the RPM between 1450 & 2100, 2200 tops but that's me, I have read they can do 2700 and go down to 1200 with full Torque around 1600-1700 RPM this is for the SO engine not HO..
Administrator
^^^ what he said
jejb
NW Arkansas
I go with the owners manual. Don't need tow/haul mode unless the tranny is doing a fair amount of hunting. If it is hunting in tow/haul mode, then use the ERS to find a low enough gear to stop that. For me, that is only in BIG hills, like out in CO. Once out of that terrain, I dial ERS back up to 6.
