After Market Rear Diff Cover??
DieselDad
Does anybody have a link to moe's for purchasing the magtech covers?
Sent from my iPad using Tapatalk HD
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Awesome! Thanks Moe!
I will order one next spring when I do my first rear end fluid change.
I probably will order one at the end of the summer just to have it ready to go. I figure I will only have barely 10K miles by next spring.
DieselDad
Thank you sir!
Recon12
WAshington State
2014 Sport
I just got my Mag-Hytek cover (from Moe's) and after reading this thread I was concerned about clearance. I have air suspension and it goes down about 2" for "Entry/Exit" mode. No problem though as this picture shows. The truck is down as far as it goes and actually sitting on the bump stops.
But holy moly, that U shaped bracket that someone described as small is pretty big IMO! I would hate to have to cut that away.
Will be installing the new cover soon...looks like something even a shade tree mechanic like me can do easily:crazy:
michaelrc51
NJ
Looks like I am going to get a the Mag-Hytec rear diff cover and tranny cover.
Anyone replace the front cover as well?
What one are you using?
charonblk07
Calgary, Ab
F1-A forged 349ci
Only PML has a front pan but you have to call them directly; I have the PML front diff cover on mine and I was part of their trial run on them.
michaelrc51
NJ
Thanks.
That kind of sucks.......I like the Mag-Hytec and would like to go the same for all 3
michaelrc51
NJ
I ordered all 3 today.
She said something about the front being difficult to install........any input on this?
What gear oils are most using......RP?
charonblk07
Calgary, Ab
F1-A forged 349ci
Only issue I had with my install is getting one bolt in but I was able to use a 1/4" wrench and 1/4" hex bit to get the bolt right by the steering rack since I couldn't get a ratchet in there. I used RP gear oil when I did mine but I'll use anything from Shell or Redline just use the correct weight for each differential. I like the Redline because it's already got the friction modifier in it.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Crazy what they charge for diff covers for these trucks. A little over $100 will get you a custom painted cover for a Wrangler D44. Poison Spyder, Ridler, Teraflex, Solid. AEV being probably the most expensive.
Still might spring for one since I tow a lot.
michaelrc51
NJ
I didn't think the pricing was bad but I did think they may give me a small discount for buying all 3 but hey......
TheRudeDog
How did your install go and did you have any issues being in "Entry/Exit mode? And did it take 5 quarts? Thanks!!
TheRudeDog
Can anyone confirm that the Mag-Hytec take 5 quarts?
TheRudeDog
Can any one confirm post number 55?
No one responded to my question and I ended up purchasing a gallon of Red Line (which already has the additive for LSDs by the way) and used less than 4 quarts (in other words less than a gallon).
Markcuda
Clinton,Illinois
2015-Laramie-1500-CC-4X4
I got Mobile1 75-140 for my new diff cover, it also has the limited slip additive in it. Haven't decided on which one to get yet.
I posted a new thread about a AFE cover, no one has responded that has used them yet.
DILLIGAF
Canada
I got the G2 adds an extra quart . I used Redline oil so I wouldn't have to use any ****** Mopar additive.
