Aftermarket fuel pump
Cgiese80
Hi guys I'm in need of a replacement fuel pump for my 09 5.7L quad cab. At this moment I can't afford to buy a Mopar or Delphi that I'm aware it's the best way to go. Anybody had experience with a cheaper brand? My budget is under 150 right now. Is a rebuild kit a good option? Thanks!
SilverStreak88
Houston, Texas
5.7 Eco Gasser
What's the pump doing? I've done my pump several times and replaced it with O'Reilly house brand "Precision" which works, but I had issues with the gauge float not reading immediately. They're are around $170, know it's a little over your budget, but I would stay away from Ebay pumps. You might have good luck with this pump off Amazon, the only thing I don't like about going this route is the warranty sometimes is an issue if it has to be replaced.
https://www.amazon.com/Spectra-Prem...-4&ymm=2009:dodge:ram+1500&keywords=fuel+pump
C
Cgiese80
I've been having issues with cranking and not starting. It did it a couple weeks ago and after hours of diagnosis nothing. Hit the fuel tank a few times and fired right up and was fine ever since but yesterday did the same thing to me while i was out and about. Hit the tank fired right up. It's gotta be the pump. Can't think of anything else.
C
Cgiese80
Maybe there is something clogging the pump?
Could be, but no matter what the situation is i will have to drop the tank to see what's wrong and since that's the hardest part I'd rather just replace the pump and be safe.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
You're not the member that I did a write-up for last week are you? I did a write-up for an 09.
C
Cgiese80
Yes sir! I'm going to follow your instructions and replace the pump myself as soon as i buy one. I have you write up saved and ready
SilverStreak88
Houston, Texas
5.7 Eco Gasser
That's what I thought, I hope the write-up helps. Like I said, I'm no expert, just try to help where I can because I know what it feels like to be stranded.
I just talked to the folks over at Spectre (the pump manufacturer), Amazon is an authorized retailer for them and they will honor the warranty (90 days) of defects. That put's my mind at ease knowing that it has an honored warranty so you should be good.
C
Cgiese80
Wow, you're the best! Thanks for going out of your way to help me out. I'll go after and purchase that one from Amazon. It's incredible but it's way cheaper than eBay for the same model
C
Cgiese80
Ever heard of this brand? I called them and their warranty is pretty good. Lifetime. And the price is even better but can't find absolutely no info on this brand :s
Electric Fuel Pump Module Assembly Herko Premium High Performance 233GE https://www.amazon.com/dp/B01N2ZGP19/ref=cm_sw_r_cp_api_aLqEyb0XGZA1W
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Never heard of it, but they are putting a lifetime warranty behind it so it better perform or they're going out of business.
C
Cgiese80
No kidding uh? The rep told me it was a mid range fuel pump. Not the best, not the worst. I might give it a shot... Or the spectra is only 20 more bucks. Who knows, some people say to stay away from spectra and others had no issues at all
DannyMK2
Long Island, NY
2015 Power Wagon
a fuel pump is not somewhere i would want to cheap out. the 'lifetime warranties' some things have are almost worthless when you have to take you truck out of commission for days while you ship out a defective part and await another unit. not to mention the hassle of swapping it all over again.
rockauto has the delphi pump and its really not that far out of your budget. thats probably the cheapest pump i would buy.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
This is my thinking, I've replaced mine 3 times and I wish I would have just got an OEM, but we do what we can with we got.
C
Cgiese80
Thanks buddy
No problem. I will be following this write up next week and replace the fuel pump myself for the first time in my life.
huntergreen
once the fuel pump goes, is there a way to mod the system so it is not an intake fuel pump?
