airflow not switching
Jerzey111
North New Jersey
2014 express upgraded to 8.4 from 3.0. today i noticed airflow doesn't change unless i switch off climate and then sometimes it doesnt change even when i turn it off and on. most of the time it only flows through floor vents. also temp controls are screwed up the same way. when i change them they dont change unless i shut off climate. would this be unit problem?? harness? or climate module??
thanks in advance
yillbs
thanks in advance
If it worked fine before my
Vote is harness
Jerzey111
Jerzey111
North New Jersey
im going to throw my old setup in there tomorrow just to make sure its not blend door issue
Joey93
