AlphaOBD, delete, and a tune
krakaman24
2018 Ram 2500 6.7L CTD
Colorado
CTD 6.7L
Started getting DEF related codes on my 2018 CTD. Warranty is done so I'm pulling the trigger on a delete.
I've messed with alphaOBD and made a few changes over the years. Minor things like DRL. Prior to installing the delete tune do I need to reset anything I've changed with alpha? I've found one post that says it's not a big deal because alpha makes changes in the BCM while the tune only changes the ECM. I'm also running a pedal commander which I'll definitely reset and remove prior.
Just trying to get a more concrete answer before moving forward so I don't brick my truck.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Its always best to ask the company you are buying your delete programing software from
G-Ride990
Administrator
Administrator
Chandler, AZ
Alfa OBD can not write information to the PCM. So you should be fine. But, I can't tell you for sure since I haven't done it.
If you have any doubts or concerns I would revert the BCM back to stock using your original backup. Then after the tune is loaded you can redo the changes.
