Alright guys.. BILSTEINS post your pics!!!
spinwax
Wow that looks great! Online the method NV doesn't look good imo. But seeing them on your truck just changed my mind!
Thanks. I was really considering something not as popular like the Method Con 6, but the NVs just look right on the Ram.
R.L.K.
Bristol , Tn.
Just ordered front bilsteins :happy107:
The key is to do the install yourself , good luck Sir ..... See my next post below....
R.L.K.
Bristol , Tn.
Or at a minimum read thru my install post , as it has a few tid bits and a couple pointers that may help on your install .....my post may also help you understand what your shop does incorrectly...if you choose to pay someone to do this for you ...
Hope this helps you Sir .
http://www.ramforum.com/showthread.php?p=1206420
R.L.K.
Bristol , Tn.
That's strange ....???? Something has changed on the Ram Forum or Tapatalk ???
Just click on where it says
R.L.K. Bilsteins set @ 2.8" ..... Above ...
akennedyusmc
So I have bils ready to order soon but why are guys upgrading their uca's? I've seen both stock and mevotech/zone. Just for extra reassurance I'm assuming?
R.L.K.
Bristol , Tn.
It's been mentioned many times ....if your truck is a pavement only 4x4. Then don't worry about upgrading your ucas , if you 4x4 often then upgrade them...imo .
I off-road often and sometimes pretty rough , that's why I upgraded my 2014. Ucas
Ravjay12
Peace of mind. The OEM ones seem to be designed only for stock height in the front. Many companies are noticing this and making UCA’s for increased front end height. Seems to keep the cv angles from getting too much out of place, too.
SeriousBlack
Live Free or Die N'Hampsha!
2014 Black Tradesman/Express Quad Cab 4X4
Alright guys.. BILSTEINS post your pics!!! - Page 3 - DODGE RAM FORUM - Dodge Truck Forums
I have read your most informative post. It has helped me make sure they will be installed correctly. I appreciate your help and look forward to mine being installed. Thank you!
VT Remmy
Another data point:
2014 Ram 1500 Bighorn 4x4 5.7L 6'4" Bed
Bilstein 5100 F & R
Fronts Set at 2.8" w/ Mevotech UCAs
Rear with Daystar 1" Spacer
After Measurements
FL 38-1/2" FR 38-5/8"
RL 40-3/8" RR 40-3/8"
Ready for an alignment and tires :favorites13:
Pictures:
BEFORE:
NqjYPIDjYQoSJrfjWfbUWAZQKO4CqsPifn4XgKkDBL1Rss1Sa6BYi1CW1pBqFHi9P73KHFzULUzvqT29C0lE9VR1KZijPfeeHXzZ12AegQoPm0hWYn8hDKhV3M-Hq6UZvmgYUt_kjBwmgBkQesd1DwvUr3GjFTNQR5J-95OXOFN334RJiWm2MC3AQJtG7Ft0nXpIOVrDX-JMEI8vStIo5xpV1C5F-ZzYJc1p0QywXbz_9axmDNXLQFMMLZX-jxeNvmLwkmssTGWOKzcQ6SziiGvJvZG9xInQph7QcByYR_b8X67Q-xhRGO8BpKAyUtS61LUvFn4-Fjqoo1i20riUOfZEes_iaWWDp8Mo1HrdUORvnL71yYoVnv1yuSZSc__J7yQdRY0qIBXVV38DOGlLlDB87etfaMxtnTBTKY6iAsWGWyAdjABiO2Dk8_NNYDypNaIqlJhs3cSt0uUunV1BhGHi8LLEDXOWc1MJSIfY5lm2RgRk-z43LK784PEnK_Sj7V-g2Ja06CZ8IHU3snA9ThCCRBV8sgRunH9RRNWHmiNywe4peCNK_iMnXV5Aj69SE4_Da_cmU3zFjMhk63Ha7D6kr8cTmv8Q6A2bAeiblg=w1026-h769-no
AFTER:
YqATIoHMtrFM7bNI270V0IOSp_mTuuj_TLaFJMl-1y6kOZGZl0qzCx2ac_qv2TB0pcPxtwK5a8BRk0w5tAkfXXIhwHmkoTXgghhoXDhFJLxAyj4QZIcLnp_bv40Z3yBXEVtZqyrdNvAJoRBpg-l81QIYZH5eksSBiTAxjGAzMkd4qFcQUgVDoMfscK4uT-nPXa1F2P5_EMxPQuPsc9BVSAdrWXX4WvXzio06mCBvzVrODvPOMcujL2zdHzl_Yfi_Ixh-dImh0vcQ-Uj0aWgYNQ2-uKF1aq36270bxADlE1OjIyILBV6ZZqePzfvDUMaLjwvv56a86WVUwOTsUfsSDcXQBMoj-2ujLJVwqWECkzZIhChPPCrcXc0XflKGhvYIdlEMi4-PSKACeEw0HH75HhEWOE0j9NLYUvXVNnts7dXNvN10b1vCyKGJqhMFV62d0AJf24jA6NBI7ueIW4MRoTYnKFDdRQZXfudzaOPwUibMCKyqD7ktxw_noDMtz0iIKe6y8bIGy9LvUjePAYpdVSvJhzwqI5ovhQrQMfBUK9bTRKk2ZWSglhaTHvtXsUl1f-VMMkuLpjd5KNbsPzEg39BO2lnZtqKderuZgUAQJKI=w1368-h769-no
JB1
Houston, Texas
Welcome Remmy, truck looks great what tires you going to put on
PCT
2019 2500 6.4
Northern California
Petty sure I'm going to go with Wrangler DuraTrac - Size: LT35X12.5R20 studded for my winter tires.
I love my Duratracs, but I have noticed that they're heavy as hell, I think there about 50-65 lbs per tire. My Mpg has dropped with the same size as I had with terra grappler, but much more traction, MUCH more.
SeriousBlack
My tire guy has them and agrees with you on traction. I'll use them for winter only.
akennedyusmc
I've read this thread a couple times all the way through and didn't see why people upgraded their ucas. Do the stock ones snap and break easier when you're off-roading?
Thinking about these as well for a piece of mind. I don't off-road often but when I do its out on the middle of now where. Better safe than sorry.
RLK your detailed thread has helped sort a lot of my questions and figure out what I want. Thanks!
R.L.K.
Bristol , Tn.
Glad I could help .
In 2013 the UCA design changed and the ball joint is weaker and is more prone to separate while under heavy loads . This issue is mainly when folks go cheep for a lift or level with front spacers .
Many have had zero issues out of the OEM ucas ...
