Alright guys.. BILSTEINS post your pics!!!
golfinds
FL
ecodiesel
Just went outside to measure for you. Highest point of the top of my truck with this setup is 75" with the XM shark fin antenna on it 78". The 2.1 setting makes it almost perfectly level. I have 1/2 inch lower in the front which gives it the level look with a very slight rake.
Sent using Tapatalk
Much appreciated. Did you change your upper controls arms ?
kempo780
Bohemia, New York
5.7L HEMI
No stock arms. They do fine set at 2.1 at some point if they do wear out I will pop in the zone UCA's for some beef.
Sent using Tapatalk
golfinds
FL
ecodiesel
Sent using Tapatalk
Thanks. You have really helped with my decision making
SportyJames
Corpus Christi
2015 RAM 1500 Sport
Looks good! It would look better without them stinkin badges. [emoji1303]
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas.
What's the best way to take them off and remove the adhesive?
Michael
In an undisclosed bunker
I used a heat gun and a plastic spluger to take it off. I also used my fingers to roll off any adhesive that the spluger didn’t get. A little rubbing compound to take care of any ghosting.
kempo780
Bohemia, New York
5.7L HEMI
Just did mine last week was easy. Fishing line to take badges off then use Turtle sticker and glue removal spray to take off the leftover adhesive with a microfiber towel.
Sent using Tapatalk
Michael
Sent using Tapatalk
Did you take them all off or just some?
kempo780
Bohemia, New York
5.7L HEMI
All. Took off the 4x4 badge, both RAM 1500, both Hemi 5.7L, bighorn badge.
Sent using Tapatalk
Michael
Sent using Tapatalk
Too bad the rams head logo on the tailgate isn’t easy to get rid of. Since I have a black truck I took the chrome one off, cleaned it up, and installed a gloss black one. It almost blends in and isn’t very noticeable.
MAJ_Charlie
VA and NC
Finally finished this last night. Started with the rears on Sunday afternoon. Didn't get to the fronts until yesterday afternoon. Got my fronts set at 2.8.
Went from stock height measurements of 35.75 (front) and 38.25 (rear) to 38.75 (front) and 39.25 (rear). Definitely need the step rails now to get in.
MidTennMtneer
Princeton, WV
Pentastar
Those of you that have done this yourselves, did you just use a spring compressor from AutoZone or something?
I put 5100s on my Equator (Frontier) at max 2” setting. We tried a rental compressor but it just wouldn’t hold the spring which had to go to almost full compression to get the strut out.
Ended up taking the assembly to a shop with the install diagram and had to pay $75.
Are these Ram springs softer and easier to compress? Is there a better tool to rent? Capable of doing it all except that part.
Justin33
Just installed 5100s and tires after reading through all the help posted here. Thanks to all who gave input!
Before:
After:
Set to 2.1” with no spacer in the rear, ended up with just under .75” rake. Sitting on Goodyear DuraTracs in 275/65R20.
I have the same express...I may have to copy your setup. I’m just trying to decide why some people are going 295 65 and why others go 35....that’s what I’m trying to decide.
olyelr
Kewadin MI
A 295/65-20 is a 35. The main difference, is most “35’s” are 12.5” wide, where as the 295 is about an inch skinner.
Nitto sells a 35x11.5/20 (which is basically a 295/65-20 lol).
HD17
So I have the bils at 2.8 and zone uca's
Will the 35x11.50 20 fit on the stock wheels? Or will the hit the uca's??? HELP
