the codes
- Jan 8, 2012
- 4,210
- 160
- Location
- Houston, Tx
- 1998
- Magnum 5.2
For my next system I am planning on going with a pretty moderate set up, however deffinitely not audiophile.
I am planning on using deadening matt and doing the doors, inner doors, and rear, and possibly kick panels.
Then I am not sure which deck, but most likely a double din, with at least 8 eq bands, bt, and 4 volt outputs.
Then I will most likely be putting a pair of 3 way speakers, paired with most likely a single 10", possibly 12"
My question is, should I get seperate amps for the speakers/sub, wire them to one amp (is that possible?), or should I just run the speakers off the double din amp, and run the sub on its own mono?
Since I am not getting a bottom of the line headunit I was thinking the speakers (also not going crazy $$$ wise on these) should be okay on the headunit??
thoughts? suggestions?
