There is a difference between lifetime coolant and "universal" or all "vehicle coolant". Lifetime coolant is just base, it is a great product. What you just put in your ram is a dex clone, see the
2eha in sds. They call it universal, that couldnt be farther from the truth. Run a dye pack through the system find the leak. I guess you will just have dex cool now, hopefully it works out, true flush is not easy at all. c
oolant thread for more info
Coolants dont have detergents, because they are meant to leave protection on the surface and detergents would clean that off. Look into rmi 25, if you get any dex damage which is gunked up, rmi 25 takes it away and deposits into the coolant resevoir where it gets trapped.
