Another new old guy needs some help.
62maxwedge
Sault Ste. Marie Ontario
i have a 2008 ram 1500 with a 5.7 that is giving me more gray hair. the truck will start after much coaxing but runs like a bag of dirt , no power and shaking like crazy but when i check it out i cannot find anything wrong and it does not show any codes on the scanner. any ideas , i need to get this thing moving asap. thanks
MADDOG
Out Exploring Arizona
Any other issues such as a blinking dash?
Check all battery connections and the battery ground.
Pull the intake tube and check your throttle body. It may need to be cleaned.
Next, check the main harness connection to the PCM. It should be dry and clean with no bent pins. Make sure it fully seats into the connector when you plug the harness back in.
Lastly, check your available fuel pressure.
62maxwedge
i checked all grounds and battery connections ok have not checked fuel pressure yetbut i was just reading another thread and they mentioned the key switch, which i have to hold to keep the engine running maybe something here? i have to figure out how to check this out ps my 2013 ram has the blinking dash which i have not been able to fix either.
MADDOG
You didn't mention the key switch issue in Post #1 but that's something you should definitely check out.
RamDiver
Marlborough, Ontario, Canada
As much as a poorly running vehicle can be a PITA to troubleshoot and resolve, especially while using online guidance, we need to start with and resolve any starting-related issues first.
Could you please describe the key switch fault in as much detail as possible?
How long has this feature been noticeable?
Is it necessary to hold it in a special fashion 100% of the time and/or what happens if used in a normal fashion?
Have you tested multiple keys to see if they all demonstrate the same problematic operation?
Have you owned this truck since new?
TIA
And welcome.gifto Ram Forum. :cool:
Dodge 1500 4X4
Rochester, NY
Find the ignition wire coming from the ignition switch to the starter solenoid, remove that wire, use a jumper wire and supple 12V to the starter solenoid, that will tell you if your ignition switch is bad.
Phillyrube
Flatistan
Just an idea, put a multimeter on the negative terminal of the battery and then on a chassis or engine ground point. Yea, sounds funny, but if it shows any voltage you have a bad ground somewheres. Ask how I know....
tron67j
Maryland
Could be a bad batch of gas with water. Put some isopropyl alcohol in to burn water out, run down low in tank and use a different gas station to fill up. That will cost you almost nothing (of course gas) and eliminates one possible issue
Justthebutler
BC
2017 Ram 1500 SLT
Welcome!! @Fullofquestions
It could be something as simple as a dirty fuel filter, or clogged air filter. You could also check your plug wires to make sure they're all seated.
StNick
Dublin, Ca
Cummins 12V
It really sounds like an ignition switch problem. If the switch is intermittent it could sure cause the truck to run poorly. You may want to jumper around some of the wires if you can get into the wiring harness. (Ask any good car thief).
Justthebutler
BC
2017 Ram 1500 SLT
This is a good idea, you could try and rig up some kind of starter switch or button.
The touching wires thing is a myth though, however the older dodges are easy to steal if you know what to break. I'm not a car thief but when I did towing for 15 years we towed a lot of stolen vehicles, especially the caravans, and neons.
