Another Ready lift thread
ReelSlim
Canada
I recently bought a Ram 1500 Laramie after running a 3500 for the last ten years. I only had the truck for a few weeks and had a flat on the stock Bridgestones. I live in Northern Canada and definitely get all 4 seasons.
I read a lot of threads on here trying to decide on tire size and brand. Should I level it or lift it. The same things that drives everyone else crazy who is wanting to make changes….lol
I managed to find a set of Toyo Open Country AT3 in a 285 65 R20. I decide that I’ll keep the stock rims for now and to be honest I don’t mind them. I also had the 3.5” Ready Lift SST kit installed.
I have only had it on the road for a few days but so far very happy with the results. The lift and the tires make it look like a truck without changing the ride much at all. A bitter stiffer but to be honest it was far too soft stock. I’m sure the tires are the biggest reason for the small change in ride.
I know these threads have been done to death but here’s another one! Lol
I also installed a set of RokBlokz mud flaps today. I know not everyone likes or needs them but where I live it’s a must. I wanted the protection but as simple of a flap as possible. These definitely were what I was looking for.
ramltd01
Virginia
This setup seems to be the favorite from my research.
I have a new 1500 LTD - and one of the shops I usually deal with said they've had issues with lifting these trucks due to the air suspension. any issues on your end?
R
ReelSlim
Canada
This is a Laramie but does not have the air ride. With the cold long winters where I live the air rides have been problematic so I didn’t get it.
R
ReelSlim
Canada
That looks great. That's the same tire and size I'm eyeing as well
It looks pretty good but in hindsight with the stock rims and zero offset the 295 65 R20 might have been better with the Toyos. They don’t have as an aggressive side wall so as say like a Nitto. I’m still happy with the look. It was a fine line between looks and being practical in snowy conditions.
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Great looking truck.
I recently took off my LT285/65R20's and put on LT295/65R20's.
I like the height increase and stance with the bigger tires, and my per tire weight went down by about 5lb even though I went to a bigger tire.
R
ReelSlim
Canada
Yeah…..I was back and forth on 285 or 295. Not unhappy but the 295s would of been perfect. If I end up getting aftermarket rims with a slight offset then 285s will look pretty close.
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Yeah ideally I'd run 295s but there's about a 6lb (24lb total) and .5" difference in the two and I commute quite a ways for work. I think the 285 is a good balance between looks and not totally killing mpg and power.
CanuckRam1313
Ontario Canada
2023 Warlock SLT
I'm getting about 1 to 1.5 mpg better fuel economy with the 295 Michelin Defender LTX M/S's vs the 285 BFG KO2's.
The bigger Michelin's are about 5lb lighter per tire than the slightly smaller BFG's, too.
The other benefits are the Michelin's road force balance out with exceedingly less weight than the BFG's, and are much better in wet conditions as well.
I do miss the more aggressive look of the BFG's vs. the tame highway look of the Michelin's, but they're growing on me...lol.
