AustinAggie
- Dec 16, 2016
- 15
- 5
- Location
- New Braunfels, TX
- 2016
- 5.7L HEMI
I drive a 2016 1500 Hemi CC SB with 3.92 rear axle (10,300 max tow rating). I currently tow a 4500 lb Jayco travel trailer (26.5' box, almost 30' total - one of the common bunkhouse models with no slideouts). I use a Reese WDH with anti-sway bars.. all without much trouble. It's noticeable that I'm towing, but no issues.
I'm considering upgrading to a bigger TT but am having a hard time figuring out how big is too big. I don't tow a lot.. started a few years ago with a pop-up (which was barely noticeable, even on my older 2004 Titan.) Moved to the TT a couple of years ago, and am comfortable towing even for longer trips. I don't want to be white knuckling the whole trip... but the advice on here is all over the place.
I know the truck can tow 5500 lbs (32' or so) or 6500 lbs (34' or so).. but do I want to? I know there are estimates I can do to look at GVW, etc.. but most of the advice is to take your setup the scales.. which I can't do with something I don't own.
How many of you out there made the jump from 4500 or so to 5500? or 6500? How noticeable was it? Any issues? Any upgrades you'd recommend to the truck? (tires? rear air shocks?) Any other advice?
Thanks in advance!
Thanks in advance!
