Anyone know what the torque spec is for the cab mounts?
09SilverRam
The South
My original nerf bars had a brace to the cab mount, I’m replacing them and my new steps brace to the pinch weld.
Anyone know the torque specs for the cab mount bolts when I retighten them? I can’t find it in the Haynes and don’t have a FSM.
06 Dodge
Forest Grove, Oregon
6.7L CTD
I never found them for my 06 when I did nerf bars so I used the old back up specification Good and Tight...
Tom Davis
Colonial Beach, VA
5.7L
My Dad has done body work for a living, pretty much his entire life. When installing mine (he enjoys helping out now that he is retired) his reply was as tight as the air wrench will go.
indept
South Jersey
Be careful with that. Us older folks remember when impact guns maxed out at 250 - 300 ft lbs. Today's impacts are over 1000 ft lbs. That much will snap some big bolts.
healthyrx
Oviedo FL
2017 1500 Sport Night
A good starting point may be the install instructions for a body lift if you can find it on a manufacturer website. I know that my zone 1.5" bl had torque specs for the body mounts. dont remember the number off the top of my head though
DILLIGAF
Canada
#3 Setting on Milwaukee 1/2 impact worked for me.
Jeepwalker
WI
2012 Reg Cab, 4x4
Put them on tight with a 1/2" breaker bar. That will do it.
Once you get your new 'steps' installed, evaluate if you think they're mounted securely or if they're flimsy. Some steps have brackets which go to the backside of the rocker, which makes the steps stronger and puts less stress on the rocker pinch-weld ....other's don't. The ones which don't can put a lot more stress on the rocker pinch seam ...and sometimes they'll break welds and flex a fair amount. Life's isn't going to end if that's the case, but sometimes fabbing up a little extra bracketry on the backside (if/when it's necessary) can make the step firmer and safer.
