Anyone run black rims in winter salt conditions?
Discussion in 'Exterior' started by Klaus96, Oct 15, 2015.
Sponsored By: BAK Factory Outlet
  1. Klaus96
    Klaus96 Senior Member
    301
    65
    Jan 14, 2015
    Illinois
    Ram Year:
    2014 2500 CC Laramie 4x4
    Engine:
    I put on some Fuel Nutz black/machined rims and wondered how the black would hold up in salty road conditions. I put Shark Hide on the machined surfaces and not worried about that. Shark Hide can be put on painted surfaces, but looks like it would be kind of a bitch. I've read and heard that the painted parts of the rim will hold up fine. Looking for firsthand experience. Thanks.
  2. Johnn123
    Johnn123 Senior Member
    2,090
    1,073
    Sep 23, 2013
    Ontario
    Ram Year:
    2010
    Engine:
    I use fluid film on my 4g for the winter. I coat my stock wheels, all under joints, all seams and box with it. Stuff works amazing. Ran through Canadian winter and you'd never know it was covered in salt most of the winter.
    jbr likes this.
  3. DIRTRIDER
    DIRTRIDER Member
    80
    22
    Jul 15, 2013
    Ram Year:
    Engine:
    HEMI 5.7
    I have aftermarket black wheels on my truck and take them off every winter and install the stock wheels with snow tires mounted on them. Living in Western NY, the black wheels would be destroyed after 2-3 winters with all the salt and grit they put on the roads around here.
    Thatdude596 likes this.
  4. Thatdude596
    Thatdude596 Senior Member
    37
    1,094
    248
    Oct 16, 2014
    buckeyes state
    Ram Year:
    2009 ram big horn
    Engine:
    put stockers on
  5. A05GSHO
    A05GSHO Senior Member
    547
    274
    Aug 17, 2014
    Southeast WI
    Ram Year:
    Engine:
    Yep I swap mine out in November to the stockers with stock sized Duratracs. Shit costs to much to let the salt fawk them up.
  6. Thatdude596
    37
    1,094
    248
    Oct 16, 2014
    buckeyes state
    Ram Year:
    2009 ram big horn
    Engine:
    yep 37x13.50s don't do shit in the ice and snow either
  7. crash_eco
    crash_eco Senior Member
    443
    123
    Sep 20, 2015
    Canada
    Ram Year:
    Engine:
    hemi
    I don't anymore but have in the past. Usually I do a full hand wash clay bar and wax before winter. When I had my black aluminum rims I would pressure wash them, then had wax them with a few coats of wax. I now use cheap steel wheels for my winter tires cause the salt is just poured on the highway. I also use dyna beads so there were no weights to get salt stuck on them. Every two weeks I hit up the pressure washer and use the soap spray then go through a touch less.
Share This Page
