anyone running a 38x13 or 13.5 tire
lilwayne
Im trying to see wat this size tire looks like on a lifted truck because I cant have the tire stick out past the fender flare over an inch...post some pics up with the tire and rim size plz
lilwayne
lilwayne
there aint know one running these or close come on now lol
norsman
Paradise PA
13.5 is not a problem and 38's will fit you just need enough lift.37's fit with a 6 in lift so add a 3 in body lift and problem solved..
lilwayne
lilwayne
i have an 8in suspension lift on my truck already i was running 38x15.5x20 the rim size was 20x12 it looks like and i think the offset is like -44.. but i have to go with a little smaller tire so it dont stick past my fender flares more then an inch...im only doing this cuz i keep getting tickets.. thts why i was askin if a 38x13.5x20 would only stick past the flare a little bit also im not sure wat for offset i need if i would have problems with my tire rubbing when i turn or not...
4x4Hemi
Edmonton, Alberta
i have 13.50 inch wide tires and they barely stick out past my fender flares. mind you i have 17s and -12 offset...
lilwayne
lilwayne
can u post some pics wat exact size r they 38x13.5
lilwayne
lilwayne
U dont have any trouble turning or anything right
4x4Hemi
Edmonton, Alberta
it rubs if im turning and go over a bumper.
my trucks alot different though being a 4th gen 1500 with a 6 inch lift
lilwayne
lilwayne
U say ur offset is -12 right so if I run a 38x13x20 with-12 offset I shouldnt have any problem with it rubbing or anything should I.... im jus cautious cuz idk alot about tire sizes and offset crap.,..cuz a 38x 13 is basically a 13.5 anyways someone was tellin me
lilwayne
lilwayne
thts how bad they stick out now with a 38x15.5 and 20x12rim with around -44 offset
[/ATTACH]
rustydagger
Near McAlester, Oklahoma
hemi 5.7 with K&N CAI and Diablosport Trinity Tuner
Hey, so you decided to try smaller tires huh. Here's a good website to help you compare sizes:
Willtheyfit.com
Its pretty simple just punch in the sizes and it will draw a diagram and help you decide.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
lilwayne
lilwayne
Willtheyfit.com
hey man thanks for tht site tht is an awesome site and it helps out alot...
Orca
