Thanks, I am interested because this system seems to run so much hotter than my last Ram. It was a 4.7 and it ran cooler, especially towing. With higher temps, which I understand to be more efficient, I am wondering if a surfactant would be beneficial….The only one that we've heard of is Lubegard Bio tech for the oil only, I wouldn't put any additive in the cooling system, besides the recommended hoat or oat and distilled water.
@Treburkulosis mentioned this in the 4th Gen forum.I was looking at it on their site. They seem to have some pretty decent products. I’d like to hear from anyone using it.
That never showed up on searching. Thanks.@Treburkulosis mentioned this in the 4th Gen forum.
Added Wilwood brakes. 6 piston front and 4 piston rear. Nice. Where did you get the kit and how hard was the upgrade?www.ramforum.com
You're old 4.7 had a 195 thermostat,while your new truck with the 5.7 has a 203 thermostat.Thanks, I am interested because this system seems to run so much hotter than my last Ram. It was a 4.7 and it ran cooler, especially towing. With higher temps, which I understand to be more efficient, I am wondering if a surfactant would be beneficial….
What is the temperature your engine s running at?Thanks, I am interested because this system seems to run so much hotter than my last Ram. It was a 4.7 and it ran cooler, especially towing. With higher temps, which I understand to be more efficient, I am wondering if a surfactant would be beneficial….
204 - 212 unloaded. A little higher towing in the hills. I wasn’t really worried as I know it is supposed to run hotter for efficiency, but it really oscillates fast in this truck. Maybe I am just not used to the digital temperature readings….What is the temperature your engine s running at?
Engines are designed to operate within an operating temperature range that benefits the efficiency of the emissions system as well as keeping the lubricants in an operating range where they can provide maximum lubricity.
I've noticed the same temperature swings on my 2022 1500 but it is an ECODiesel. The temperature reported on the DIC, once warmed up, will swing between 198 and 209 degrees (F) and usually stay at 203 degrees. Interestingly I have a Bank's iDash on this truck and the direct reading from the CAN bus doesn't show the same temperature swings as the DIC. This leads me to believe DIC has an algorithm in place to smooth the temperature reporting that may need some further debugging.204 - 212 unloaded. A little higher towing in the hills. I wasn’t really worried as I know it is supposed to run hotter for efficiency, but it really oscillates fast in this truck. Maybe I am just not used to the digital temperature readings….
