Arh headers
12vrunner
Texas dfw
Ok guys got my american racing headers i went 1 3/4 catless with y pipe. From the guys who have installed these any tips or tricks. They came with no instructions but im assuming pretty straight forward. And im thinking my gaskets came pretty mangled so probally goin to get some 6.1 hemi gaskets.
DILLIGAF
Canada
The best part of headers is the custom tune :)
Its pretty straight forward. Do Driver side first :)
Reinstall the dipstick tube before you bolt the drivers side header on solid.The bolt on the tube might give you trouble.I unbolted the driver side motor mount and jacked the engine up to gain enough clearance to remove it,some guys are cutting the bracket instead,either way will get the bolt out of the way. Stock up on beer,lots of it will make the job easier,lol
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
When they don't work out, please let me know and I will take them off your hands. :naughty: I'm really interested in the process you're about to go through as I have been considering a set also.
Thanks,
Jay
12vrunner
12vrunner
Texas dfw
Lol dont worry if they dont work out ill just hang them from my rear view mirror. And yes i will follow up with how it goes probally install next weekend.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
There's no need to worry about the fitment.....they go right in.... no denting required....lol. Not sure about the oil dipstick on the 2500 but on the 1500 had to be modified or turned a bit but that's about it. Good luck! Also if you havnt installed them...I highly recommend getting the ceramic coated on the inside and out. Had a local coating company do my ARH and Y pipe inside and out for $300. Helps with heat and flow as well as protects them. My headers still look brand new after 2 years of use...I had them coated in silver.
Regina, Canada
Do dipstick tube issues on 2500 at all. I have them in and they went in fine. A little bit of contorting to get the locking nuts I bought snugged up, but install was straightforward.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
So whats the hp/torque gains on a set of ARH headers with a Hemifever tune ?
12vrunner
12vrunner
Texas dfw
Hey guys just following up havent installed headers yet just decided and dropped them off to get ceramic coated. And going to pick up 6.1 hemi header gaskets from factory. I will keep you posted on any updates.
DILLIGAF
Canada
Mopar gasket are just rebranded fel pros. save your money and pick it up from the parts store/
Hipps2000
Hemi 5.7l
Glad to hear your getting them coated! You won't regret it....I also used new mopar gaskets as well as stage 8 header bolts.
12vrunner
12vrunner
Texas dfw
Yea decided to spend the money on the headers mine as well go all out lol. And to be honest was down to rock the arh gasket but came trashed i could probally get a new one sent actually havent tried just figured oem 6.1 gasket were a good choice.
Hipps2000
Hemi 5.7l
Defiantly oem is best...many recommend them.
Regina, Canada
they look good! should be straightforward.... I've installed a lot of headers, mostly on old musclecars. These were by far the easiest headers that ever went in.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Do you mind if I ask how much the coating was? They sure look good
Jay
J Rod
Ft. Wayne, IN
Great, something else to add to my "to-do" list. Thanks a lot!
Those look amazing btw!
Hipps2000
Hemi 5.7l
Coating can range $250-350 depending on where you are.
