ARH Longtube Headers for the 2014-15 2500 6.4
Dubstep Shep
Houston
2014 R/T
Any reason to look at these vs the 5.7L ARH longtubes if I go to the 6.4L?
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
No difference between the 5.7 and 6.4 headers. I will be running my 5.7 1500 headers on the new 6.4 motor build as well.
wyo2track
western Wyoming
2014 RAM 2500
6.4L Hemi w/ 4.10's
So am I reading this correctly. There is no difference at the exhaust manifold with port and stud alignment between the 5.7 and 6.4 headers? Forgive my ignorance, my automobile knowledge is limited....:emotions133:
Air in, air out...sure was important on my old 5.9 CTD. So, with the same header design as the 5.7, is this impeding air flow for the 6.4, choking air flow from flowing into the engine or is it more tuning? I keep reading how little gains are when the restrictive OEM muffler & air filter is replaced with aftermarket products that something else must be restricting air flow...
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The ports on the heads of the 5.7 and the 6.4 are the same, so the headers will fit both motors.
On the 5.7 trucks, we are seeing 25-30hp from the ARH longtubes. Guys are even putting up 60-65hp gains from the ARH longtubes with a custom tune. I see no reason why the 6.4 wont respond just as well. Log manifolds are made cheap and a major restriction. Longtube headers will always show a nice bump in power on just about any motor.
drittal
E. Montana
Has anybody gotten a dyno of their 6.4 with headers???
theviking
I've been waiting for tuning on the 2015 to become available. Need to remove the speed limiter, otherwise you can't get a full run in 4th gear.
drittal
E. Montana
How does it feel compared to stock without tuning?
theviking
Just driving around it feels much better under part throttle acceleration. Under full throttle, definite improvement but wouldn't call it dramatic. I timed it before/after with SpeedPro on my Android and it was 1/2 sec quicker to 60. Not sure how accurate the tool is but was repeatedly getting about 8.0 sec after the headers. Torque management bs and the 6200lb curb weight don't help things here.
Here is a quick video with a couple of first and second gear hits. I posted another one a couple of days back but that was just a quick throttle jab on my street. FYI, I also have a Magnaflow cat back kit installed.
https://www.youtube.com/watch?v=k8uWuJobUZU
drittal
E. Montana
Where did you get yours and,if I may ask, what did you pay?
Do you think it is worth the expense?
Was the exhaust a large improvement over stock?
Do you Tow?
I am asking because I tow now. I'm not looking for 1/4 mile blasts, but improvement dragging 10-12k down the highway. If I could get another 30hp and significant torque I might consider it now.
drittal
E. Montana
What about torque? I'm towing a fairly large TT with mine now.
theviking
Do you Tow?
Yes, I tow but typically just a two horse trailer or open car hauler. Nothing quite as heavy as you are towing. I bought mine through Moe's Performance (Matt) when he was having a special. I'd call him and see if you can make a deal.
Yes, I believe they helped throughout the torque band. But for your purposes, I wouldn't necessarily say they would be worth the expense without a tune. IMO, a custom tune would likely provide the biggest benefit for your buck. Or if you tow often, I'd consider putting the money toward new gears.
Orca
