flecker
I hate this pos truck... and need some help before I set it on fire and roll it off a fawkin cliff.
1996 Dodge Ram 1500 2wd, 5.9L automatic. It starts and runs... However, after about 5-10 minutes it just stalls. It typically does it when it goes into gear.
I have replaced the tps, the iac, pcv valve, the pickup coil, the maf, the temp sensor, the intake plenum gasket and checked for vac leaks. I have also checked the o2 sensors in the last year and replaced the one furthest away from the engine (back).
WTF am I missing here? Is it possible a crap crank sensor would cause a stalling issue when bad? More often after it warms up?
Since I replaced the iac, the issue has actually gotten a bit worse.
I HATE this dam truck.
Halp.
I am just trying to get it running smooth so I can sell it.
Halp.
