flecker
So I have checked for codes since this all started... all I ever got was a code 12 (batt. disconnected in last 50 starts) and a code 55- end of sequence.
It literally just threw a code 11 after I drove it around the block and parked it when it stalled again. ******* Dodge has hands down, the worse engine management system known to man.
Code 11 on a 1996 Dodge Ram means that there is no ignition reference signal detected during cranking (bad Hall effect) OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor.
So more than likely the crank shaft position sensor is toast? WTF?
Dodge sucks balls.
Sorry to vent, but dam!
Thanks for your guys help so far...
Dodge sucks balls.
