automatic headlights
dare_nm
2016 2500 4x4
hello, im new to forums trying to see if anyone knows why my headlights just stopped switching from dimmed position and brights. got in the other morning turned corner and car was coming at me . so i manually changed to dim, ever since on auto will not kick up to brights , on dark hwy at night.
Do you have the 8.4 radio? You might have to go into the "settings" on it and check to see if it's still activated
Damion
2019 Sport
I thought you had to have the lever in the bright position for the auto high beam to kick in. Mine doesn’t have this but I think I read something along those lines
jasonw
South Dakota
5.7L Hemi V8
You are correct. You have to have the lever in the "high beam on" position for the auto-high beams to work. If they are in the low-beams position, it turns the auto-high beams off. Works this way in my 2014 Ram, and the wife's 2014 Grand Cherokee.
If the auto-high beams are turned on in the UConnect system, as Wild One describes, when you flip the lever to the low beams positon, you'll get a "automatic high beams off" (or something very similar) message on your dash. When you flip it on, you'll see the opposite, a message saying "automatic high beams on."
RamInfo
Utah
5.7L HEMI
JasonW has it nailed, this is exactly how the automatic lights work in my Laramie.
DG
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Something else to add...
When the Automatic High Beam function is enabled (in both the radio vehicle settings & stalk pushed forward) at night...
- High beams won't turn on until the truck is over a minimum speed (@ 15mph)
- Will automatically turn off high beams with approaching vehicles.
Some pictures...
http://www.ramforum.com/showthread.php?p=1562474
M² Mods - From my non Flammable S7!
