Axle Seals
RAM_007
5.9L
Does anyone know much about axle seals? I have a 97 half ton and I changed the passenger side axle seal 4 times since last May and it still leaks. The vent is clean and I burrowed an axle puller from a shop in town so i know the seal goes in straight and that it goes in all the way. Any help would be greatly appreciated. Thanks
ramhunter9
P-Star Jeep Wrangler
Axle seals are a touchy install . I tired these 2 times on a buddies truck and every time it leaked . Paid 100 bucks had a shop do it 0 leak and 20k miles so far .
R
RAM_007
5.9L
lol I think Im getting to that point. Im just kinda stubborn.
R
RAM_007
5.9L
Is it possible that there is something wrong with the axle itself, or something else up there? Or do i just suck it up and take it in to a shop?
RubberFrog
It could have a burr from when the seal was originally installed and/or removed.
R
RAM_007
5.9L
Everything looks real clean, no burrs or anything like that. Could the bearing be bad?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
^^Like Frog says and Use double lip seals as I believe Dodge ones are not. Talk to your local Gear Shop or Napa Counter Guy. Good Luck!
R
RAM_007
5.9L
Well no shop in my hometown would work on it, they said if my dad cant fix it they dont even want to try. Luckily i found a shop about 30 some miles away that will give it a try. So the moment of truth is tomorrow morning.
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
lol The 2nd gens were bad for that, and I don't think they make a double lipped seal for them either. You almost have to have a surgeon's hand when it comes to the install on those.
R
RAM_007
5.9L
Thanks guys, I will let you know what happens.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Thats a bummer. 3rd gen must have thicker axles? i just figured they would be the same rear end set-up/seals but then again I do know the studs are bigger on 3rd Gen. thanks for pointing that out Chris. fingers crossed for you Bob!
reds
italy
cummins 5.9
hello
i have a seal of dana 60 front axle leaking oil
but I can not find the parts, usually buy from rockauto.com, why send in Italy abuon price. but I can not find it.
Can you help me find it, giving me a code or a link where to find parts
thanks
reds
italy
cummins 5.9
help me !!!
is fine with me also the code of the original parts
Ftank
