Backed truck off ramps with exhaust disconnected and many codes came up
Believer45
Ohio
6/7 Cummins
I had my truck (2011 Ram 2500 6.7 auto, 166K miles) on ramps in my driveway working on an exhaust leak. I started it with the exhaust disconnected and backed it off the ramps, shut it off and the check engine light came on, a lot of codes came up. They will not clear, cannot clear check engine light. Anyone have any ideas where I should start?
CodeStatusNumberComment
P02E9Stored1 of 12Diesel Intake air flow position sensor circuit high level 2 of 3
P049DStored2 of 12EGR Control position exceeded learning limit
P2579Stored3 of 12Turbo speed sensor circuit performance
P2BACStored4 of 12Nox exceedence - deactivation of EGR
P049DPending5 of 12EGR Control position exceeded learning limit
P02E9Pending6 of 12Diesel Intake air flow position sensor circuit high level 2 of 3
P2579Pending7 of 12Turbo speed sensor circuit performance
P2BACPending8 of 12Nox exceedence - deactivation of EGR
P049DPermanent9 of 12EGR Control position exceeded learning limit
P02E9Permanent10 of 12Diesel Intake air flow position sensor circuit high level 2 of 3
P2579Permanent11 of 12Turbo speed sensor circuit performance
P2BACPermanent12 of 12Nox exceedence - deactivation of EGR
Administrator
Until all the sensors have been reconnected, codes won't clear. Also some of the emissions related codes take a certain number of drive cycles and/or time for the codes to be cleared.
Believer45
Believer45
Ohio
6/7 Cummins
Crash68 thank you for your reply. All sensors have been reconnected for close to four months, no change in the issue. The truck ran disconnected for less than a minute. Everything was reconnected and truck was started again, the codes all showed up. Truck has been driven just shy of 3,000 miles since this happened. The truck runs fine, only issue is the remote start will start truck but it will only idle for 10 seconds or so and shuts down. Check engine light is on, fuel economy is fine (16.4), power seems fine both towing and bobtail. I keep thinking this may self clear but no success so far.
Believer45
Believer45
Ohio
6/7 Cummins
Went out and cleared codes, rechecked before starting engine and had this:
P0101Stored1 of 9Mass Air Flow Sensor "A" circuit performance
P02E9Stored2 of 9Diesel intake air flow position sensor circuit high
P02E9Pending3 of 9Diesel intake air flow position sensor circuit high
P0101Pending4 of 9Mass Air Flow Sensor "A" circuit performance
P2BACPermanent5 of 9NOx exceedence - deactivation of EGR
P2579Permanent6 of 9Turbo speed sensor circuit performance
P2002Permanent7 of 9Diesel Particulate Filter efficiency below threshold
P02E9Permanent8 of 9Diesel intake air flow position sensor circuit high
P0101Permanent9 of 9Mass Air Flow Sensor "A" circuit performance
Believer45
Believer45
Ohio
6/7 Cummins
Started engine and ran at idle for a few minutes, rechecked codes and had this:
P0101Stored1 of 8Mass Air Flow Sensor "A" circuit performance
P02E9Stored2 of 8Diesel intake air flow position sensor circuit high
P02E9Pending3 of 8Diesel intake air flow position sensor circuit high
P2BACPermanent4 of 8NOx exceedence - deactivation of EGR
P2579Permanent5 of 8Turbo speed sensor circuit performance
P2002Permanent6 of 8Diesel Particulate Filter efficiency below threshold
P02E9Permanent7 of 8Diesel intake air flow position sensor circuit high
P0101Permanent8 of 8Mass Air Flow Sensor "A" circuit performance
Believer45
Believer45
Ohio
6/7 Cummins
Looks like one pending code left right now, along with two stored and five permanent codes. Pending is P02E9 intake air flow position sensor high. Truck still runs like new, no issues. I am thoroughly confused, any help where to go from here?
Believer45
Believer45
Ohio
6/7 Cummins
I have been thinking about getting the AlfaOBD program and needed hardware. Would that do better at diagnosing than a basic scanner? I am currently using a Zurich ZR13 that, for the money, seems to do pretty well.
Administrator
AlfaOBD is usually capable of reading and resetting more codes than a typical reader. There are even testing and calibration modes that it can access also along with reading live engine data while it's running
Believer45
Believer45
Ohio
6/7 Cummins
Thanks, Crash68. I will get what I need ordered and dig into this again when I have everything here.
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
looks like you got a wiring issue I would be back tracking where you was working that day on exhaust and check every harness near where you was at seeing that it came up after you done the work wires are broken or lost connection within its connector where ever that may be
Believer45
Believer45
Ohio
6/7 Cummins
RamRod37, thank you for the reply. Good idea, I will dig into it on a warmer day. I do not have a garage and am working on a gravel driveway.
Believer45
Believer45
Ohio
6/7 Cummins
GTyankee, thanks for a great resource. I bookmarked it for future issues. This supports RamRod37 saying to start with wiring. I really appreciate it.
