Bakup camera
Discussion in 'Audio & Electronics' started by Terryd, Jan 10, 2017.
  1. Terryd
    Terryd Junior Member
    Jan 9, 2017
    Ram Year:
    Engine:
    2015 ram 1500 bighorn if i have the locking tailgate will the harness be in the tailgate for the oem backup camera?
  2. Brew99
    Brew99 Member
    41
    Nov 14, 2016
    Victoria, Canada
    Ram Year:
    Engine:
    3.6
    Not likely....you would need to crawl under the truck and see how many wires are at the connector that is at the centre tailgate to bed transition area. If you only have 2 wires, then best bet is to get the entire install kit (which has a replacement in tailgate harness with a camera connector). If you have 6/8? then you might already have the required wiring.
  3. 00R/T
    00R/T Supporting Member
    1,448
    894
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    I'd say it's very likely. Everybody I know of who has added the camera, even if they had no other portion of the wiring, had the part in the tailgate (if they had the lock).
    R.L.K. likes this.
  4. baum
    baum Senior Member
    1,746
    346
    Aug 26, 2013
    savage, mn
    Ram Year:
    2015 Laramie
    Engine:
    The plug itself is the same BUT the wire are not there. If you go with a factory back up cam kit you have to re-pin that harness and also re pin to the bcm and radio
  5. R.L.K.
    R.L.K. Supporting Member
    9,846
    5,619
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    There are two different harnesses inside the tailgate for the camera , the larger of the two harnesses do in fact have the camera wires 6ea and 2ea for the lock .
    The kit comes with this harness as well . So you'll have an extra one .
Share This Page
