Belltech 2/4 - How Long Before From Settles?
B
BeBeep
I will definitely give that a try Monday. I need to give everything a shot at this point.
Thank You
WhiteExpress
Midland, TX
Shock looks installed perfectly fine to me. Not that it's super helpful. :-(
My guess is that you got front springs for a crew cab or something.
trev
What year is your truck? I called belltech a couple days ago and they said they don't make a lowering kit for a 2012 ram 1500.
B
BeBeep
My truck is a 2010.
I removed the shocks and lowered the truck but it did not make any difference. It was worth a try anyway.
robby5323
East Texas
2014 Single Cab
My truck is a 2010.
Well at least you know the springs are the culprit... I'm guessing they are the wrong springs for your application.
B
BeBeep
The mystery appears to be solved after I talked with the Belltech folks. The springs I received in the kit are for a Chevrolet. WTF!!!!
I called Jegs and they were very apologetic and are sending me a set of front springs ASAP. I cannot complain about their customer service as they were right on top of it. Now I need to wait for the new springs, get them installed and hopefully I will be good to go.
Thank you all for your suggestions, etc I very much appreciate it.
chipmaker
AZ
Yeah for finding the root cause!
B
BeBeep
I just wish I had found it back when I first got the springs. :D
garner
Harker Heights, TX
Chevy springs fit on a ram? That's an interesting one. Wonder what else fits...
KLRpanda
did they put the rear coils up front and the fronts int the back?
B
BeBeep
I received the replacement springs from Jegs and had the mechanic swap them out today. Looks 100% better with the correct springs installed.
Thanks to all who helped me work thru this issue.
WhiteExpress
Midland, TX
Just looks so perfect. I love it man!
Sounds like I might be moving to a city... Won't need all that ground clearance...
Whitehemi
FL
what size tire is that ? Sweet lookin truck !
B
BeBeep
Thanks to everyone for the positive comments, i really appreciate them. :)
