Best way to clean out buttons?
nlambert182
Huntsville, AL
I just picked up the new truck in my sig and noticed that the exhaust brake and rear parking sensor buttons are sticky. They do work, but the buttons take a second to pop back out once pressed.
I noticed some "goo" squeezing out of them when pressing. It's a clear goo and almost looks like the shop that cleaned it up sprayed something on it to shine it up like a silicone tire shine. Any suggestions on how to get this out without damaging the switch panel? I've tried some interior cleaner and a small toothpick but the gaps are so small around the switches that I can't get much in there. Would it hurt to spray some electronics cleaner in there to see if it will clear?
Travelin Ram
Probably safe, however I’d test the solvent first on an unobtrusive spot to be sure it won’t mar the finish.
If you can find a solvent that will remove the product they used and not damage the dash, I’d try a small fine bristle brush to use as a tool to agitate the material in the crevice.
Treburkulosis
Your High End Detailer
Haslet, TX
Take a picture and post it. I will see if I can help you figure it out. Im leaning towards Shine Supply solution or Koch Chemie ASC.
nlambert182
nlambert182
Huntsville, AL
You can see a little bit on the center console. It's clear and super sticky. Not sure what it is but I've seen silicone tire dressing (I think it was Eagle One) get really sticky like that. To note - the tires were coated with a similar mess as well. It took a lot of effort to get it off the rubber.
NCRaineman
NC
2019 1500 Classic
You can *carefully* pop the surrounding trim out and go after it with rubbing alcohol and a cotton swab.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Are you sure it's tire dressing? It could be that someone just spilled a soda or some other sweetened drink on the buttons. Rubbing alcohol won't be very effective for that. It might be good to just try cleaning with a damp rag to see if any of it comes off.
nlambert182
nlambert182
Huntsville, AL
I don't know what it is but there is no color to it. It doesn't have the consistency of any type of soda that I've ever had to clean off. I did try wiping it off with a damp rag and again with some Chemical Guys interior cleaner. Both times it just made the rags a sticky mess.
I used to do some car detailing on the side and honestly the closest thing that I can compare it to is the Eagle One tire gel based on consistency. I will say that whatever they put on my tires had a similar feeling. It took a lot to get that stuff off. I messaged the dealership this morning to ask what their clean up guy uses, and he said he had no idea.
I will say that it wasn't noticeable at all until I started pressing the buttons. Prior to that it wasn't visible.
The wife thought that it was superglue at first but it never gets hard. It's just a gooey mess.
Treburkulosis
Haslet, TX
View attachment 530957View attachment 530958View attachment 530959
I would get these two things and clean them really good. It won't hurt the buttons. I use it on most all of my details.
Daw14
I would try a vacuum to try and remove what you can followed by alcohol .
Dodge 1500 4X4
Rochester, NY
Try some Dawn dish detergent, put some in a bowl and dilute W/ water use a sponge on the buttons followed by a lint free cloth see if that works, ant then a vacuum to suck up the solution.
nlambert182
nlambert182
Huntsville, AL
Thanks! I have a set of detailing brushes in my car cleaning tool box. :) True story - long time ago I used to have a side hustle detailing cars. Nothing to your level, but I made some decent side cash with it until my real job took all my time. Now it's just maintenance washes.
I also have a couple of different interior cleaners. I was afraid to spray them too heavily. I'll give this a shot.
ralphsmithiii
use a really soft toothbrush and interior detailer
This typically works pretty well. If you have a steamer available, you can use that with your interior cleaner. Just need to make sure that you cover the steamer head with a microfiber towel in order to not damage any of the plastics. But, I would use that IF none of the other methods solve the problem. It will clean that up, however.
Atcer2018
Virginia
How’s the radio? Has it ever been replaced? I ask because your truck is a 2018 and the 2018’s are notorious for the delaminating 8.4 radio touchscreen. I’ve seen a defective radio leak the LOCA or liquid optically clear adhesive. It’s super sticky and equally hard to remove. The buttons you show in the pictures are directly below the radio and the prime spot for the adhesive to drip down onto. You could have a defective radio and it will continue to happen over and over even after you clean the buttons or its residue from an earlier replacement/repair. That button panel is removable after you remove the center stack trim. It’s secured to the trim ring from behind by phillips screws. If it is LOCA it comes off with isopropyl alcohol but scrubbing the buttons with isopropyl alcohol may remove the black coating/paint.
BWL
Embrace the skeptisism
BC Canada
Just get some electrical contact cleaner. Safe for cleaning terminals and the plastic. Should rinse out any grease or whatever is in there and then evaporate away. Disconnect the battery first if worried and give it a few minutes to clear out.
nlambert182
nlambert182
Huntsville, AL
No it hasn't been replaced and yes I am aware of the issue with the 2018s. My last one was also a 2018 and I replaced the radio in it. I am going to be replacing the screen in this one down the road. I mentioned in one of my threads that the glue is the glue from the screen. It's not showing signs of delamination but it is.
I've removed the switch panel and tried cleaning with isopropyl and all it did was essentially remove some of the paint from the buttons. I've got to attempt to disassemble the switch panel to get underneath the buttons.. that's where the glue is sticking.
I did try electrical contact cleaner as well and it had no effect.
BWL
BC Canada
I've had the buttons fail in the past as well. The metal bits that act as button returns broke internally. They still worked most of the time but they didn't click like they once did. Eventually I just replaced the panel. Hopefully you manage to get it cleaned out and it works, but glue is pretty tough to remove from electronics without damaging anything. The solvent to remove glue is pretty tough. 3m makes an adhesive remover that works pretty well, but you'd have to take the switch apart to get it in and out of there. Take a pic of the panel. Maybe one of the members that has switched it out to add the aux switches happens to have one off a truck with the same options they can sell for a reasonable just in case https://www.rockauto.com/en/catalog...switch+&+relay,instrument+cluster+switch,4524
When i saw that, first thing that came to mind was the sticky stuff that is used to apply Automotive wood grain vinyl.
The second thought was a delaminating radio.
Just this week, a video was posted that shows exactly how to disassemble the Auxiliary Switch Panel
