beavermosh
- May 8, 2013
- 56
- 27
- 2013 Dodge Ram Big Horn 4x4
- Hemi 5.7L 390HP
Go through the plug right above that grommet, its for the clutch master cylinder and unbolts from the inside.
Sent from my Galaxy S3 using Tapatalk 2
Its not really the size of the woofer, its about how much power. I know of tens that will take 10k watts, but really as long as you are staying under 600w rms you should be ok. I personally change equipment enough that I like to run 4 awg or bigger but thats me. That is a pretty cool connector do you mind if I asked where you found it? Good luck with your install.
