Bilstein 5100 install - Are new UCA's needed for 2018
JimRam2018
Georgia
I'm planning on getting new bilstein shocks and struts installed on my 2018 ram crewcab 4x4. The main reason is to level the truck. Two questions:
-The shop says some owners replace the upper control arms when replacing shocks, but they redesigned for 2018 models so it wasn't needed. Any reason to go ahead and replace?
-Any reason to go ahead and replace the rear shocks with bilsteins at the same time? The truck has 30K miles and I don't know of any issues with the rear. Additional cost with labor is $250.
-It sounds like the 2.1 setting is the best setting. Any reason to go to 2.8?
Appreciate your feedback.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
2.1 should make it sit level.
Jay
Ohio5pt7
Ohio
No need for ucas your shop is trying to make more coin.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Yaple57
Buffalo NY
From what I've read. Most guys that get ucas have the level at 2.8 and only do it as a precaution. Its not needed though and definitely not needed at 2.1. That's what I have gathered, someone correct me if I am wrong.
JimRam2018
JimRam2018
Georgia
Thanks for all the advice here. Ended up getting all 4 bilstein shocks/struts and set front at 2.1. It's slightly below level at 2.1 but will keep it good when stuff in the bed. Happy with the ride and how it turned out.
Orca
