Bilstein vs. Spacers
Wrigley17
Howdy. I have done my research and seen the overwhelming voted in favor of the bilstein 5100's for a level. My question is for the spacer route, who makes the best ones and what is the best material? Rubber, or steel? I want to narrow it down and compare that spacer to the bilstein. With spacers would I need taller shocks anyways? I see some brands say their spacer kits require different shocks/struts. Just trying to do my research because I don't enjoy redoing anything.
For tires I have the stock 275/60/20 on my 15 CC. What sizes have you guys gone up to on a stock set up, and which sizes have you gone up to with a 2 inch level, including the bilstein set at 2.1 or 2.8? I don't want the tires wider, just a taller more aggressive tire.
Thanks in advance gents, I have gained a plethora of knowledge from these forums.
RotorHead04
MA
I just posted two Billistein 5100 series 24- 186988 to eBay if anyone is interested. It's for an 06- 08 1500. I bought them but couldn't install them due to a rusted on control arm.
So many guys like me have had some problems with bils on 2.8, so I say 2.1. There is more stress on cv boots/joints at 2.8, and there have been issues at take off at that level, but overwhelmingly there haven't been many problems with bils at 2.1. I had spacers and removed them for bils, way improved my ride quality. Spacers bind your from end, don't go that route. Either poly or metal, doesn't matter they will last.
W
Wrigley17
Ok thanks for the help. Just narrowing my options. Do the bils keel the factory ride? I really like how nice my 2015 handles the road. Any noticeable mpg decrease with a level?
2.1 leaves some rake, 2.8 pretty much levels it perfect. You can trim the back springs as well, as an option if you want 2.1 and a perfect level cut 1/2 inch off the back. Yes, gas mileage goes down at least 1mpg.
The factory ride is improved with bils, really will ride nice and a little firmer.
W
Wrigley17
Ok thanks for the input.
W
Wrigley17
What tire size will fit with no lift/level? 275/60/20s now.
michaelrc51
NJ
Bils, made a much better ride.....even the wife drove my truck and noticed the ride difference.
I also did the 1.5" body lift and 35" fit no problem with the Bils set at 2.1" and a 1" spacer in the rear. I did Bils front and rear.
BigChief
SW Ontario
I have the bils set to 2.1 on my 2014. I have 37.5" front and rear to the top of the fender. It is leveled. I think 2.8 would be too much for my truck and my mechanic advised against 2.8 for all the same reasons you see here.
I put Goodyear wrangler duratracs on and they measure nearly 35". They are 285/60r20. They look great and fill out the wheel well nicely.
PCT
2019 2500 6.4
Northern California
If you haven't made your decision yet, I did 2.5 RC spacers. I didn't notice ANY ride comfort changes at all... I had them installed at a autoshop, so I cost me about 300 out the door for parts and installation. Looks good IMO, I'm running 33's
W
Wrigley17
I agree, your ride looks very clean and how a truck should. Thanks for the input, glad to hear spacers haven't caused you issues.
W
Wrigley17
As in ride do you mean handling and comfort? That's great she could notice a difference.
W
Wrigley17
Sounds like bils are the route to go. Anyone have them put in that will share cost? I could do it myself but am curious what it would cost in labor for a shop.
BigChief
SW Ontario
Locally, CAD$ it cost me 235 with 13% TAX and an alignment. Pretty darn cheap if you ask me. I was quoted 2 labour hours and $60 for the alignment.
PCT
2019 2500 6.4
Northern California
Sorry didn't get to this sooner.... The truck still drives like it was when it was stock! Both handling and overall comfort
Sparkz
I just had Bil's installed on my '14 along with Mevotech UCA's. I had them set at 2.1" and it's just about perfect. Total cost was $202 for the Bil's, about $90 for the UCA's, $400 labor to install them (NY prices :( ) and another $100 to have the wheels aligned. Not cheap, but worth it if you're like me and hate that downward rake.
Now I'm searching for new 17" tires to replace my OEM's - Thinking Toyo AT II's
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Check out the Guide to Leveling & Wheel and Tire Sizing linked in my signature. It will tell you everything you need to know about Bilsteins VS spacers and what size wheel/tire setup you can run with the leveling kit.
Cfpdscott
I don't have pictures but I just did bilsteins set at 2.8 on my '11 CC and added 1" spacers in the rear. Gives it a little rake but lifts the whole truck and looks real good. Still have stock tires I plan on adding either 33's or 35's in the future
