Blend door part number?
Bloody_Knuckles
USN 81-86
Lebanon, TN
I have a 2004 Ram 1500 quad cab, 5.7 hemi, single zone heat control.
Does anyone know the Dodge part numbers for the blend door and recirc doors?
Do I need to get two blend doors for a single heat control system? It appears there might be a linkage between two doors that I can't see.
Also what is a good website to buy them from?
Third question, is it possible to replace the blend door without removing the air box? I've watched a few youtube videos but it isn't clear how they replaced the blend door. I certainly don't want to cut a hole in the air box and patch it with speed tape like some repair kits do.
Fast69Mopar
Mopar Blend Door for Single Zone ATC from www.moparpartsinc.com
5073992AA
Mopar Recirc Door Housing with Actuator
68004226AD
I get the Recirc Housing from my local dealers for under $50.00
Please do not cut into the HVAC housing to repair the blend door. Take your time to do it the correct way and you will have a longer, happier service life.
HemiLonestar
MD
5073992AA
68004226AD
Do I need two blend doors?
Don't confuse the two, blend door is for temp, recirc door is for inside or outside air, two different locations, two different doors, both of which like to take a **** on you at inopportune times and are a royal pain in the **** to do anything about.....
Bloody_Knuckles
Bloody_Knuckles
USN 81-86
Lebanon, TN
On the parts diagram it appears that there is an upper and a lower blend door connected by a linkage. I'm pretty sure that the upper door is broken, but I'm unsure about the lower. From what I've read, it's the upper door that breaks but not the lower. Am I correct in that?
Fast69Mopar
If you have a Single Zone Automatic Temperature Control system, you have a blend door, recirc door, mode door and a defrost door. If you pull the HVAC housing out and inspect it, you will find the defrost door assembly on the top of the case on the left. The recirc is on the top case on the right .
If you split the cases you will find the blend door sub-assembly in the lower housing.
