Boost
thieves
HEMI 5.7
Has anyone tried boosting the current gen RAM?
If so, which turboz did you go with? How much boost are you running? What are you using to monitor your temps, ATFs, etc? Single or dual? Turbo location?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Unfortunately, because you cant tune a 2012, it is next to impossible to run any kind of boost. Your best option for big power is nitrous.
schroederMP
Indiana
Cummins
And if you end up running boost...don't go over 8lb or say bye bye to your tranny
03lowram
Houston, Tx
5.7(Hemi)
Theres's a twin turbo 4th gen Ram.. I think he ran 12.1 one of his first times on the track with it. He built his own kit, I dont remember what size turbos though.
He's almost building a turbo set up for another 4th gen..
Stangshcky12
Oshkosh, WI
5.9 Cummins
There are a few companies that sell supercharger kits for 4th gen rams
RIPP has a bolt on kit that fits '12s I believe
SmokedRam
Zephyrhills, Florida
YOu could always do a PCM swap...thats what a bunch of the Challenger guys are doing.
audio1der
Airdrie, Alberta
Absolutely. If you're going as far a boosting a stock engine, there's no benefit to trying to leave the limiting factor (PCM) stock. Swap/re-flash and give'er!
thieves
thieves
HEMI 5.7
Well I'm coming from a 2010 speed3...so I guess I just need to hope for a tuner soon. However, which PCM should I be looking at if I were to consider it? 8lbs seems so low compared to 18lbs on those disi engines.
Don't think I want a supercharger, I am biased toward the benefits of a turbo...
reyzapien88
