Both rear only turn signals not working
RamAz
I developed a weird issue. Both of my rear turn signals do not work. Fronts work absolutely fine. Rear light bar blinks when the selected turn signal is on. Four way hazards work fine also. Trailer turn signals also work. truck in question is a 2017 Ram 1500 QC. No LEDs and I have factory quads up front and factory rear brake lights. Just started happening Friday afternoon.
Administrator
You definitely have something odd going on. I'm guessing your tailgate bar is wired to the trailer plug? Those are on a separate fuse and circuit from the tail lights. The trailer turn/stop signal gets its signal from the BCM which runs the rear tail lights.
If the hazard flashers and the brake lights work but it's just the rear turn signals that don't, I guessing the problem is with the BCM? Would need the factory wiring diagram to confirm the rear light wiring.
ajairola
Houston
Do your rear tails still work as brake lights? Highly unlikely but maybe both bright filaments burned out.
RamAz
RamAz
I believe I’m going to head to the dealer. I’m stumped.
RamCares
n/a
n/a
Hi RamAz,
If you are in need of any additional support while addressing this with your dealer, please do not hesitate to follow up with us via private message.
Mark
RamCares
RamAz
RamAz
It’ll be a few days, I guess the dealer is backed up.
Hi RamAz,
Mark
RamCares
RamAz
RamAz
