Both of these are illuminated now. I searched and found two possible answers, speed sensor, and or low brake fluid. I just replaced the speed sensor and the brake fluid is fine. What is my next step, the ignition key code trick brings up no codes.
BTW, I just replaced all the rotors and pads, and I replaced one of the rear calipers. Did I damage something. How do I get a ABS code if its not showing up?
