duckman631
- Jan 9, 2019
- 341
- 253
- Location
- New Jersey
- 2016 Big Horn Crew Cab
- Hemi 5.7 K&N Cold Air Intake.
i recently had the factory brake controller installed at dealer. 2016 1500 4x4 crew cab. Instructions were non existent. I understand the whole let the truck roll and squeeze the brake controller and should allow for a smooth stop. Not enough or too much, adjust the gain. Currently set by them at 3.5. My main issue with is the dash indicator. I have on the screen a meter from 0-100%. Even without a trailer connected, when I brake to a full stop, I noticed the meter goes to 100%. When I am hooked up, will that only indicate the percentage of the brakes on the trailer? Do I want it to go to 100% when I brake the truck when attached to trailer or should it be less because I want the truck to brake more than the trailer? I can’t find any info on that part f the brake controller operation. Towing travel trailer about 6000 lbs loaded.
Thanks
Thanks
