Barrett Palumbo
2500 2014. So I had a soft to the floor break pedal, so I replaced the master cylinder today. Same issue. NOW WHAT..thanks I do have power steering..
Did you bleed the system after you changed the master cylinder? Also did you check for blown/rusted brake lines.2500 2014. So I had a soft to the floor break pedal, so I replaced the master cylinder today. Same issue. NOW WHAT..thanks I do have power steering..
x2 gotta clear it, somehow air got in system. Very common to stay soft til it's cleared.The shutter valves in the ABS controller must be bled via a computer, in addition to bleeding the rest of the system.
