- Joined
- Apr 28, 2012
- Posts
- 23,361
- Reaction score
- 45,256
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
How could all of the other pads work and the oex not with this? Not sure, but I'd try.Do you guys think I can still run these EBC anti vibration shims with the new OEX pads?
I thought these where unique and I’ve never seen them before the EBC pads.
EBC was the only pad I’ve ever see with silencing shim fit into the brake caliper piston. All my others I’ve ever used have them glued to the back of the brake pad steel. The EBC used both and not sure if that would cause any issues if the pads aren’t designed with that in mine. As long as I have enough room for the pads I’m gona try. I got the rear OEX pads and they look good but very weird.How could all of the other pads work and the oex not with this? Not sure, but I'd try.
@blackbetty14 there is a lever behind a removable lower dash panel to the left of the steering column that allows you to manually put a ZF8 spd into neutral.I did not know that about 8 speed, so no way to put park truck in neutral?
