Break lights
Scotty_12
Tampa
Ok guys, Having problems with my break lights on my 04. Driver side break light was out so i replaced ALL lights bulbs. And still out. Not sure what is going on here. Any help would be appreciated.
BWL
Embrace the skeptisism
BC Canada
Pretty common on those years to have a bad socket. Try wiggling the bulb in the socket with the brakes applied if you have a helper or put the flashers on. Sometimes you can bend the tabs to fix the connection, but best to just replace the socket.
MADDOG
Out Exploring Arizona
I'm assuming you meant the brake lights?
MADDOG
That's what they're called when they work, but when they're broken a case could be made for break lights. Lol
nope nope nope nope ...
Reactions: BWL
grpht03ram
It's probably that circuit board the light bulbs plug into. I've had to replace 2 of them.
HemiLonestar
MD
Those circuit boards are absolute garbage. I was glad to finally find a plug and play LED setup that I didn't hate.
russrap
Hilo, Hawaii
5.9L Diesel
Replace your circuit boards, Common problem, I have to replace mine a couple of times already.
