Brightest bulb that isnt HID?
CumminsPastYa
5.9 Cummins
So im bored of the stock headlights. I tried HIDs and they didnt work and i have no idea how to make them work so if you know how let me know on a 2006 dodge ram 2500. But other than that, what is the brightest bulb i can get? Let me know!
novalok
Why didnt the HID's work for you? which brand did you go with?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
right.......what brand?
twooldfarmers
SK and AZ
2014 Laramie Crew 4x4
I think the problem may be that the bulbs sold on the web as HID's are not. HID's are a special bulb that sometimes comes with a different reflector unit (head light assembly) and requires ballasts/igniter unit for each bulb
IMO the crap flogged on the net are just a zenon bulb at best
Stangshcky12
Oshkosh, WI
5.9 Cummins
Most HIDs are HIDS, they have a seperate ballast the changes the voltage and current to the bulb
Most run them in factory housings but the proper way to do it is in a projector
Xenons usually use a hotter temp bulb or a filter on the glass to give the appearance of a white(er) light
Csanders1992
Sylvania zxe are pretty good
JustinRam1500
