Someone on this forum recommended this for changing plugs: GEARWRENCH 3/8" Drive 6 Pt. 5/8" x 6" Magnetic Swivel Spark Plug Socket - 80546 https://a.co/d/fzTWGEVThank you for the input, it’s crazy hard to get at these.
man you could definitely recommend having that little beauty around for ANY spark plug job, right? it looks optimal.Someone on this forum recommended this for changing plugs: GEARWRENCH 3/8" Drive 6 Pt. 5/8" x 6" Magnetic Swivel Spark Plug Socket - 80546 https://a.co/d/fzTWGEV
If the ceramic broke off as 1 piece,a small magnet might latch onto it enough to pull the ceramic piece out,then use an air compressor and vacumn at the same time to blow and suck out any left over pieces. You should always blow out the plug tubes before removing the plugs.I think the ceramic broke off, but I will try your idea. Thank you guys very much!
I finally figured it out, had to take brake cylinder and booster off. Then I was able to get the plug out and yes the ceramic was broken in pieces so I taped a 3/8 hose to my shop vac and got out all the pieces then the plug finally came out.do u still have the steel tubes in place?
You need to invest in one of these sockets Bubba,they'll make your life a whole lot nicer when you do plugs on anything that uses a 5/8" plug.I finally figured it out, had to take brake cylinder and booster off. Then I was able to get the plug out and yes the ceramic was broken in pieces so I taped a 3/8 hose to my shop vac and got out all the pieces then the plug finally came out.
That tool is worth its weight in gold. The best $15 you'll ever spend on your Ram.You need to invest in one of these sockets Bubba,they'll make your life a whole lot nicer when you do plugs on anything that uses a 5/8" plug.
80546 3/8" Drive 6 Point 5/8" Magnetic Swivel Spark Plug Socket 6" - Gearwrench
Count on GEARWRENCH to get the job done. Get the 80546 3/8" Drive 6 Point 5/8" Magnetic Swivel Spark Plug Socket 6" here.www.gearwrench.com
