Coventrywoods
2016/2500/6.4 hemi / 53K miles
Been chasing this nightmare with no avail. Dealer is clueless and truck is out of warranty. Sick of them wanting to throw darts at it on my dime. There's a slew of things that it could be and I'm in the process of going through the basics. Connections , shorted wire , ABS sensors , ac pressure switch etc.
Truck goes into 4high , 4lo & 2wd fine. Light comes on within a few miles 98% of the time as I'm on the brakes every time I drive it. Around a parking lot it's fine .... Get it above 15 MPH and there she is. Dash light and message clears once shut off but is stored in memory.
Twice on start up (after over night) when shifting into reverse it seems like the e-brake is on and it binds up. A few times forward to reverse and it frees up. When the light comes on and while driving it doesn't seem like it's trying to put itself in 4high or low but it seems this issue leads I to that at some point.
The last time it was at the dealer they told me they couldn't duplicate the problem so they reset the light and said if it comes on again it's the shift motor on the transfer case. 800$ part and 2 hrs labor (1k plus) So I sourced out a new OEM one for 220 and put it in my self. Light still comes on. Dodged about an 800 dart on that one.
Truck is bone stock , no after market anything other than wheels & tires I did at 30k. Stock size , just went with an aggressive tread. The wheel sensors have been screwed up since the day they went on and throwing TPMS warnings. I have went back to stock wheels hoping maybe the warnings were messing with the system. No luck on 4x4 Serv light but TPMS is back to normal with no warnings.
My question is can I just disconnect the connector at the transfer case motor and the fork actuator in the front axle to keep it from trying to go into 4x4. This way at least I can drive it without worry of it going into 4low at 80mph on the highway. This way I can keep picking things off as time allows without worry of hand grenading my 4wd system.
